Speedometer gear seal
I have a trans fluid leak at the speedo gear housing. All I can see is the gear shaft with a E clip holding it in. Later speedo gear housings I have dealt with have a seal there. Thinking this should have one too. Does anyone know where I can get a seal ? Maybe a part number that I can try at our local seal and bearing store. What about different fix? Thanks to all.
Is it leaking around the outside or from the shaft? I believe the shaft is sealed with an O-ring and I'm unsure if it replaceable. It might be easier to just replace the housing and/or the gear. I can see where its possible that the plastic shaft may wear over time, but I would think it more likely the internal seal has just worn out.
It appears to be coming out of the speedo cable nut. I think I had the housing out before it didn't have a outer seal on it. The big nut made on the housing appeared to have a machined surface on it.
I have something like what you are describing but I feel mine is probably coming from the shift shaft, hard to tell when the Old Lady's whole bottom is wet.
If I remember correctly there isn't a O ring on the speedo cable but there is on the inside of shift shaft are you sure it's not the shift shaft?.... Tedd
Tedd, I do have a small leak at the shift shaft. The big puddle , not a few drops, is coming from the speedo cable . The screw cap made on the cable I found to be cracked from being over tightened. It was leaking a bit before and I have drove it a few miles. I had really snugged it up and guess it took a bit for it to really start leaking. I have a cble on a parts car. Looks like a pain to install. Back to the shift shaft. Can I put a new oring on it from outside the trans or do I need to drop the pan? Thanks.
Tony72Cutlass'S'
April 4th, 2019 07:48 AM
27BlacK
September 13th, 2015 05:39 PM
