58 Brake conversion
Old June 25th, 2018, 08:17 AM
Rjharp's Avatar
58 Brake conversion
Hey guys. Has anyone done a brake conversion on a 58 Super 88? Is it a direct bolt on into the same location under the steering shaft? Where did you get it from? Was it difficult? Any help would be awesome.
Rjharp is offline
Old June 25th, 2018, 03:29 PM
Tedd Thompson's Avatar
Try Disk Brake Mike he has had inexpensive kits a viable for years . his personal car is a 57 converted.http://www.discbrakemike.com
Keep in mind that if you go to disks you will also have to change the master cylinder as the Tredle-Vac will not support a newer system. Also now (unless there is something new) your old wheels cannot be used with the new brakes, then of coarse your new wheels probably will not accept the old hubcaps. ... Things to ponder... Tedd
Tedd Thompson is offline
griffey57
June 19th, 2018 05:47 AM
griffey57
May 24th, 2018 07:03 AM
Skeetman
June 20th, 2017 08:37 AM
Charly9g
May 12th, 2013 05:00 PM
59-59-59
Brakes/Hydraulic Systems
June 30th, 2008 01:01 PM
Quick Reply: 58 Brake conversion
