The Mistress came home on the hook. Electrics again
On the way back from Cool April Nights my voltage regulator (I think anyway) took a dump. It is about a 200 mile round trip jaunt and I was lucky to get within 25 miles from home before the battery drained and she would not start.
Rather embarrassing setting in the Walmart parking lot waiting for a tow truck while people walked around and complement my car. What do you say to someone... Yea she is a pretty Old Girl but she won't run till the tow truck comes
This has become a serious issue as most of you know I travel big miles in this car and for years it has been stone reliable . Just get in and go but the quality of the electrical parts lately have been crap and starting to give me the nerves shakes when getting far from home. I have replaced 4 generators and 3 voltage regulators in the last 6 years, some were bad on arrival, new in the box so no miles or tows were involved, but they were junk parts from the get go.
Today I went over the electrics and have just about narrowed it down to the voltage regulator again I think. That regulator is no more than a year old and looks like it's new for what that's worth. It appears that it some how looses it's polarity and stops allowing the juice to charge the battery. If I put a charger on the battery and bring it to a full charge put a load on the battery the regulator will start to work again for a while but can't be trusted to continue. Generator appears to be putting out 14 volts at a high idle all the time so I think it's OK.
Other than just replacing the voltage regulator and hoping that I get a good one I don't know what else to do. It would be nice to know why this is happening rather than just throw a part at it and worry if this will happen again down the road somewhere distant. Any ideas... Tedd
Tedd:
I know you are big on keeping your car all original. I have a one wire alternator on my 54 and it has performed for several years. What you might consider is on of those companies that makes alternators that look like generators. The advertise in Hemmings. Just a thought.
One of the things I tell people when I am in one of these situations (and we have all been there and will be again) is that the old gal has had some cosmetic surgery and my look brand new but underneath she is still 64 years old. They usually chuckle.
These are kind of expensive, one of these might be worth considering. The picture is of a 6v PN 82057.
https://www.summitracing.com/search/.../submodel/base
Tedd ,sorry for your bad luck, but this crap gets old quickly.I know you love originality, but the unit above gives the original look and most of all reliability. Those tow bills don't come cheap anymore, go for it, and leave your aggrevation behind. Larry
I'll find a good regulator this can't be rocket science but I'm sure curious why this is happening on two different regulators., has me wondering if I looking at the wrong part for problems..... I keep you posted when I get it figured out.... Tedd
Maybe try this one Tedd ,
https://www.ebay.com/itm/1955-1961-C...Naytlx&vxp=mtr
Kinda pricey , but , you can be sure it will work right .
Are you getting aftermarket regulators? Certainly it could be several issues but I have pretty well stopped buying foreign "new" parts due to these problems. Clearly a 60 year old nos part can be bad as well but unless it looks like it's been stored in a wet basement, I've found ponying up for a GM original works well. Some have crazy prices from left field but if you are patient, you will find cost effective parts. Although even at some of the prices on eBay, look at what dealer part prices are for modern cars and folks bitch but pony up without hesitating so go figure. Those parts are readily available and expensive, but obsolete 30-70 year old parts that are difficult to find that actually help keep these cars on the road are expected to be nickels.
Tedd, sorry for your troubles. About a year ago, I feared I might be headed down your road. I replaced a generator, then a voltage regulator right away. Got a bad regulator. But the replacement and combination all seem to be working, for now.
I know I'm a little frustrated now, I also know this will work it's self out shortly.I just hate to lose my confidence in my car to the point I don't take it far out of town. The Old girl has been a lot worse shape than this..... Tedd
If it "must" be original, getting quality parts should be your route. On my '55 slow speed driving on a hot summer's night with A/C, lights, etc. running, the battery kept losing ground as far as charge level went. The solution was the alternator. It's not original, but works better. Of course alternators are not without the possibility of failure. After many years of use, a diode can fail. So far, mine hasn't.
And Ozzie what are you doing up so late or is it very early where you are? Us old people need our beauty sleep you know.... Tedd
Bad kitty
TEDD
IF IT HAS **** / TIRES
Buy an extra regulator and the boost box gizmo too
Hope you evade TOJO for a long while
april is almost over
I hope the rest of the year is fun
all the best
brian
all the best
brian
I do plan on another Concourse this year if all goes well (I know I'm a glutton for punishment) and I plan on getting as much done on the car as I can afford and what my body will allow. I have ordered a new regulator and It's should be here Monday or Tuesday. Hopefully that will the end of the problem, it worked before it will work again. I have two old used regulators in a box somewhere in my junk but I'm afraid to use them Although they could be better than something new who knows?
And I wish that I could get some regular good sleep. I'm two hours ahead of you, but I have some irregular sleeping habits. This is another gift I got with old age. So, instead of just lying there inspecting the ceiling, I'd rather get up and read the forum or something else. Then I might be a bit useful.
Perhaps you could get the old regulators refurbished?. If they are the correct part for the model year then it won't hurt your concours chances.
Back in the day millions of cars all over the world clocked up plenty of miles with a dynamo and regulator taking care of the electrical demands.
Roger.
Roger.
Tedd although my 64 F-85 is not even close to original(Pro-touring build). I feel your pain, I'm having new parts fail and the car is not in the street yet! Just ordered another brake light-cruise control switch-determined no brake lights. Just had the Power Master 90 amp alternator rebuilt few weeks ago-
I'm on my fifth or sixth regulator. Ever since Reno, the system works OK for two or three months, then zilch. Just pulled gen and reg for trip to repair shop for last time, then I'm going with those fancy gen looking alternators.
You still see NOS Delco regulators on eBay, would they be any better? Or even an older NORS like a Borg Warner?
This one is suppose to fit 55-56 with A/C. NFI
No luck but bad luck
Well I replaced the regulator yesterday and the amp gauge showed a nice + charge, Thought everything was a done deal, then I started smelling a burnt rubber smell.The generator is toast.The lead in the armature has melted and there is now a internal short. Geeees, no luck but bad luck. I probably bought a 120.$ regulator that I didn't need. New armature will be in the generator shop tomorrow, hopefully I'll have it back in the car that evening or the day after for a Saturday car show...... Or I'll take the Miata it always runs..... Tedd
Check you wiring carefully . Usually generators will not "melt down" like that unless there was a direct short to ground .
Replacement parts are garbage. I carry a container of spare parts in the trunk, hoses, regulator, alternator, starter, ignition module, coil or the whole distributor and tools. I will probably get burnt eventually when a part fails and I put on a new replacement part that doesn't work. I know replacement parts for my 70 and 88 are always order parts, I can't imagine finding parts for a 50's car. Hope some luck comes your way.
Charlie that is the main concern now. This is the second generator in a row that went up in smoke and I always ether blamed a poor rebuild on a Willson generator (which there has been two that were dead on arrival) or a bad regulator. This has been a expensive learning experience.
As far as parts go I have a good old world generator/ starter re builder shop in Hamelton City that I use if I can't get something locally. It a bit of a hike for me to use but he does a lot of old world cars and tractors and carries around 350 armatures in stock. He didn't have one for my generator but he got one over night through one of his sources. I'll pick it up today and with luck get it together tonight and chase down where my problem is, I think I'm getting closer... Tedd
Tedd,
I know this is an obvious question, but have you checked the grounds? Specifically the ground from the block to the firewall at the back? I had a bit of corrosion under the connector where the cable bolted on. Hidden. Like you, but not as bad, I was frustrated, and cleaned and checked every connection on the car. It might not be one thing, but a combination.
DFitz, I added a extra ground from the regulator # one post to the firewall a couple years ago because of regulator / generator problems at that time. This time I removed all the paint on the attachment parts of the generator in the hopes of eliminating any bad ground issues that might be hiding there. I also gave the wiring a good going over and can't see any breaks, rough spots or burnt areas. The regulator is wired and bolted in and I believe it's ready to go.
The last Item is the generator and if my legs hadn't pooped out I would have been ready for a test run tonight. Very close to being done I think.
By the way the brand new regulator needed adjusting before it would continue to charge. John Larkin (generator shop owner) ran a test on all the components together and caught this before I installed the new parts or it would have been a bad news day again. Sticky points that wouldn't make contact unless they were touched. He ran the generator and regulator on his test bench many times till he was satisfied everything was up to snuff. I recommend him highly..... Tedd
Larkin Automotive and Electric 530-826- 0250
Dave
Done deal, car is back on the road. I should have had the old generator and regulator checked before I started swapping parts.That could have probably saved me the price of a regulator and having to take it out a few times. Kinda a problem I've had that goes along with lack of patience.Thanks for the advice it all helps when I'm trying to noodle a problem out.... Tedd
Good stuff. At least you have a spare regulator now. I'd make a power kit for the old bird with your jumper and regulator and generator and tools and a good flashlight and be ready for the next time.
Tedd Thompson
May 2nd, 2017 11:07 AM
projectheaven
January 8th, 2012 09:17 AM
