Crankshaft pulley removal to change front motor mount on a 324 - ClassicOldsmobile.com
Go Back  ClassicOldsmobile.com > Vehicle Lineup > Vintage Oldsmobiles
Crankshaft pulley removal to change front motor mount on a 324 >
Old February 24th, 2018, 02:29 PM
Greetings everyone, Has anyone had the crankshaft pulley off from a 54 Olds? I have two questions. Is the 3/4 nut holding on the pulley right or left hand threads? And does one need a wheel puller to get the pulley off. I have to replace the front motor mount and that crank pulley has to come off.
Thanks, Gawain
Gawain is offline
Old February 24th, 2018, 04:11 PM
2blu442's Avatar
I ran into something like this before. Here's the thread with a reply from one of the 1954 experts!
https://classicoldsmobile.com/forums...962-394-a.html
2blu442 is offline
Old February 24th, 2018, 04:20 PM
2blu442's Avatar
OK, I found some pictures. The balancer and pulleys come off together. There's a keyway in the crankshaft, and once the bolt is removed you can pull or gently pry maybe tap with a mallet to remove the assembly. I'm 99% sure they were normal thread, just on there really really tight. But one of the guys who knows this vintage better than I can speak to the thread direction.
2blu442 is offline
Old February 24th, 2018, 04:30 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I have had the one on my 54 off a couple times. If you have an impact wrench it is your friend in getting the bolt loose. It is just a big right handed thread. The pulley and balancer are all made together. It comes off pretty easy. It may take a little soaking and some tapping because it has been on there so long.
redoldsman is online now
Old February 24th, 2018, 07:26 PM
Tedd Thompson's Avatar
X2.... What they all said.... Tedd
If you don't have a impact wrench and it doesn't come off easily you can lock up the flex plate through the starter hole with a crow bar or heavy screwdriver and attack it with a breaker bar...... Tedd
Tedd Thompson is offline
Old February 25th, 2018, 02:48 AM
Ozzie's Avatar
You have good advice. I held the engine from turning with a turning tool on the flywheel and loosened the bolt with a 3/4" drive socket and a big breaker bar. If you can't tap the pulley off with a soft hammer you can use a gear puller; just don't pull on the ring. Upon re-installation the Olds shop manual recommends using POB number 3 sealer on the crankshaft and key/keyway to discourage oil leaking. It also recommends using a new lock washer. I don't remember doing either, and nothing leaked or came loose.
Torque to 45-50 ft-pounds.
Ozzie is offline
Old March 12th, 2018, 12:22 PM
74 2.8L Capri
DFitz's Avatar
All good advice, and correct. I've had mine off a couple of times. Used an impact wrench. I Also had to replace the front engine mount. Be very careful on the front oil seal. Mine leaks, and I've replaced it several times, and still leaks like crazy.
DFitz is offline
Old March 12th, 2018, 12:40 PM
I have the front motor mount -- and the rear bell housing mounts for both stick and automatic, if you need them....
Feel free to call me -- Craig -- 516 - 485 - 1935 ... Long Island, New York if you can call the United States for free..... or if not, e-mail me....
mobileparts is offline
1950 Model Olds
Tech Editor's Desk
July 20th, 2011 10:02 AM
hawks70
June 15th, 2011 12:07 PM
D Appeldorn
May 24th, 2010 10:21 AM
rustycragars
December 3rd, 2009 11:46 AM
sssingo
November 9th, 2008 04:47 PM
Quick Reply: Crankshaft pulley removal to change front motor mount on a 324
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
