57 or 58 carb to bellcrank to transmission linkage
I am looking for the linkage from a 57 or 58 Olds beginning from the carb all the way down to the long transmission rod that hooks onto the side of the transmission. I also need the bell-crank that the linkage and throttle rods are hooked up to. The linkage I need is specific to a 4 barrel carb. Thank you! Nick
Nick if you don't get a answer here drop on down to the vintage forum and ask there . several members there have a Hollander catalog and may be able to cross reference over to a earlier or later year that would work. I'm thinking a late 56 may work with a little adjustment of the long rod(from bell crank to transmission)and would give you more options.... Tedd
aliensatemybuick
November 14th, 2011 07:01 PM
