1957 371 engine questions.
Old June 26th, 2018, 08:11 AM
  #41
Tedd Thompson's Avatar
Just something to check for piece of mind. Did your machine shop put the correct galley plugs in or maybe forgot to put anything in the distributor galleys? These are the small plug with something like a .40 thousands hole in them to oil the distributor gear. If left out you will have very low oil pressure and the upper end will be dry, common mistake by those who do not know Oldsmobile's .
As stated above first generation Oldsmobile's don't sling much oil at all compared to it's Chevy brothers..... Tedd
Tedd Thompson is offline
Old June 26th, 2018, 11:19 AM
  #42
Phantom Phixer
Charlie Jones's Avatar
Originally Posted by graysuper88
Thanks Charlie. What about the little bit of oil that is needed for the valve stems?
Evidently the stems get enough . They have umbrellas on them to prevent them from getting too much .
Did you disassemble the rockers and shafts and inspect for wear , when you did the overhaul ?
A rocker shaft that is clogged with sludge will slow down oil flow too .
New shafts are a good idea when you overhaul anyway , because you eliminate the dirt and sludge that may be there . Rocker arms that are worn more than .002 out of round , or have badly worn tips , should also be replaced .
Yes , you may remove the head bolts that retain the rocker shafts . It will not disturb the gasket seal .
Charlie Jones is online now
d2_willys
September 18th, 2009 08:19 AM
rays1930
September 17th, 2009 09:13 PM
rays1930
September 15th, 2009 01:17 PM
Kennybill
February 11th, 2009 12:34 PM
Nailhead 88
June 3rd, 2008 08:32 AM
Quick Reply: 1957 371 engine questions.
