HELP front seal dimensions
Hi from New Zealand. Apparently I haven't been on since 2012, probably because we have done a stint in Australia. Finally back and reunited with my 57 Olds 88. She has the original 371 tri-power engine, but on our return promptly threw her harmonic balancer. The guy who is re-attaching it to the pulley for me, needs a couple of measurements. Firstly the diameter of the end of the crank, which I have in metric with the use of a micrometer (but imperial would be a help). More importantly is the size of the front seal (behind main pulley). So if anyone can give me the internal, external and depth/thickness measurements of the seal it would be much appreciated. Cheers Lorry` gmail me if poss on gloria.haycock@gmail.com
Welcome back,I dont have the dimensions but Ron's Classic car gasket's ( on EBay) has the front timing seal listed by itself,for $10! Hope this helps.
If this don't help, you should Email Ross Racing Engines or Mondello Olds Engines, they both are well known for Oldsmobile engines.. Good luck ,Larry
http://www.rockauto.com/en/moreinfo....488717&jsn=405
70rocketpilot
August 4th, 2018 06:10 AM
Levellord
Wheels and Tires
May 31st, 2017 08:52 AM
