Gas pedal removal
Old July 8th, 2017, 02:21 PM
tricordati's Avatar
Gas pedal removal
Hi. I need some guidance on how to remove the gas pedal on my 1956 88? I am installing a new master cylinder and need to pull back the carpet. Thanks
tricordati is offline
Old July 8th, 2017, 02:46 PM
I moved your post to its own thread, no need to hijack an irrelevant old thread. Someone should chime in and help.
oldcutlass is online now
Old July 8th, 2017, 02:54 PM
tricordati's Avatar
Old July 8th, 2017, 06:48 PM
Tedd Thompson's Avatar
It should just pop off the gas pedal rod which fits into a rubber cup on the bottom of the pedal. If you need to remove the whole pedal I believe there is a pin at the bottom that can be removed and that will allow you to lift the whole thing off... Tedd
Tedd Thompson is offline
Old July 8th, 2017, 07:30 PM
Proud Viet Nam Veteran
redoldsman's Avatar
On my 54 the pedal itself just pops onto two little studs at the bottom of the pedal that have a little ball on them. The pedal is not connected to the linkage at all. It just pushes against it.
redoldsman is offline
Old July 10th, 2017, 08:01 AM
tricordati's Avatar
That did the trick. Thanks
beamjp
December 11th, 2016 02:15 PM
R8der4life
June 4th, 2013 06:51 PM
My442
May 2nd, 2010 04:24 AM
jensenracing77
February 7th, 2010 05:30 AM
64starfire
June 12th, 2009 07:43 AM
Quick Reply: Gas pedal removal
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
