55 Olds steering gear conversion
Has anyone done a steering gear conversion in a 55 or know some one who has. I am looking to replace my steering sector with a later model unit which is smaller.
Are we talking steering box or the selector? Some are using the Jeep box but nothing I know about is a direct plug and play, some fabrication will be necessary. Have you thought of having your old box rebuilt or do you need extra room for a dual exhaust setup?..... Tedd
X2 on Tedds mention of the Jeep steering box being a very popular swap into many different autos. You can probably find information about this swap on the "HAMB" forum.
I've seen the Jeep steering boxes in many street rods and smaller cars and trucks.
Larry
Larry
GM had a steering unit known as Saginaw 605 that came in many smaller GM cars. A site called (www.carnut.com ) has a complete article with step by step photos of installing this unit into Tri Five Chevrolets. Take a look and I think this would be very similar to what you are trying to achieve. Best of luck, Larry
The Grand Cherokee box is a popular swap into A body Cutlasses to get a quicker ratio. I seem to remember somebody swapping a Cutlass box into a mid fifties Olds with quite a bit of fabrication. If the Jeep box would swap into a Cutlass it should be adaptable to your 55 maybe. The 605 box is a popular swap to Tri 5 Chevies as Larry mentioned.
If it is the exhaust, as Tedd mentions, it can be done. With a kit from Waldron Exhaust, it is pretty easy. The pipes do fit very closely around the stock power steering. I wrapped that part of the pipe in header wrap. The pipes were a good fit and no bending was required. If you want it, here is a link to Waldron.
http://www.waldronexhaust.com/
Steering sector conversion to Rack and Pinion
In searching for the sector conversion I have found that the 55 OLDS can be converted to rack and pinion for around $500.00 and will be a neater job and free up major engine space. I will post photo's and a complete parts list once I am done with the conversion. The parts cost is with all new and rebuilt parts, if you can find the complete rack out of a 1989 to 1992 Chevrolet Cavalier or similar GM car it would be a lot less cost. will post more later.
O-dawg
November 3rd, 2016 06:07 AM
Cman7713
Drivetrain/Differentials
March 20th, 2016 08:11 AM
Delmont 88 PA
September 17th, 2013 05:28 PM
