no brake lights
no brake lights
Hi Folks Yesterday I drove my friends 1957 fiesta wagon to a big car show & as I,m following him in his 1955 98 2 door hardtop, I noticed he had brake lites working when he used his signal lites [either r side or l side] . But as he came to a regular stop he had no brake lites. Any ideas where to start looking for the problem? Thank you in advance. Friskyjake67
It's not uncommon for there to be a poor ground do to corrosion between the tail light base and the body of the car. Even though there are two large bolts holding the light on and they can be tight there is nothing to keep moisture out and it corrodes there.
On a second note I have seen this happen several times but never two at the same time so maybe there is another issue..... Tedd
oldstuff
September 13th, 2011 08:03 AM
Del70
August 2nd, 2011 04:40 PM
