55 Olds front splash apron
Has anyone seen a 55 or 56 with the front splash apron intact? So far every Olds that I have seen has only small pieces remaining or none on the car at all. Fender well splashes are easily to find but the fronts seem to be unavailable. Also does anyone make the stock metal clips that hold these rubber pieces on?
This is the rubber splash that attaches between the front cross member and the radiator support, the sway bar goes thru holes in the right and left sides and is attached to the front frame.
I have no evidence of any kind of rubber splash in front, anywhere by the sway bar or radiator supports. However, there were remains of a burlap cover over and around the front cross-member that protected the fuel lines to the fuel pump.
If it is what I'm thinking, my front splash is metal. Possibly, yours was missing and someone retrofitted something?
I've enclosed pictures of the front. Let me know if you have any other questions.
Dave
Thanks for responding Dave. The rubber splash shield fits under the fuel line and has holes that correspond with the holes on the front cross member, there is a cut out for the hard fuel line that connects to the rubber fuel line. The splash is in two pieces, each side has a hole that the sway bar goes into. The ends that go up on frame ends that have holes for clips that hold them in place. The front of the splash connects to the radiator yoke in corresponding holes. This produces a splash and air direction wall for the radiator. If you or anyone else is interested in this piece I know someone that has started manufacturing them from old patterns. I know they fit because he brought one over and installed it on my car (his splash is for the 56 Oldsmobile but with some small modification it works on my 55). These splashes are made from masticated rubber like the originals.
First time in all my years playing around with a 55 that I have see what that part looks like when complete, most are all gone or just a piece or two left. Learn something new every day on this site.... Thanks ...Tedd
I am heading over there in a couple days to get my set, what year do you have? If you are okay with the $45 I can ask him to put a set together for you. He is having to make mine I guess he didn't have any in stock at the moment.
Thanks very much. Dave
Dave
I installed the front aprons today. This is a masticated rubber piece that is made from the same material as the fender well seals above the A-arms. These also use the same push in clips as the fender seals.
2 pieces, left and right. There is a hole that the sway bar slides into, and the back is pinned up against the front of the cross member. There are 1/4" holes in the front of the cross member. Anyone ever wonder what these were for? They are for the front apron pieces. The front of the piece goes on the front side of the lower radiator mount. They fold around the bottom and front of the radiator mount.
You'll have to remove both ends of the sway bar, and jack the car to get to it from underneath, but not too bad. It took me about 3 hours, and I'm slow.
The outboard end of the flaps lay flat on the top of the frame rails just outboard of the radiator mount. I had to remove a radiator recovery tank on the passenger side, same spot as the windshield washer reservoir, and the battery tray on the driver's side to get at the top of the rails.
These seem to be long lost parts that very few know about because of the age and deterioration of the original parts. If anyone is having cooling problems, this should also help direct more air through the radiator.
CMCPRO, Olds Scott, and I have contact info for the guy making the parts if anyone wants any.
Pictures above. Dave
Tedd, I bet it was only on cars with factory air, because I don't think my '55 had that on it , and it was the most original car that I have ever seen, with only 38,000 miles and garage kept from the day it was new. Larry
I have to say, I found the old push pins in the holes in the lower radiator frame and cross member, and I found the remains of some burlap around the pins. Cliff said that the rubber part had a burlap like twine or reinforcement in the middle of 2 layers of the rubber sheet.
The evidence on mine leads me to believe Cliff, and that this part was on all Olds. He included a sheet from an Olds manual that detailed the part. He also said that, back in the day, he was a service tech on these cars, and remembers the parts.
As I've said before, this car has been in my family since new and can guarantee that it has not been messed with. Since my base model, 55 4-door Holiday 88 had the apron, my bet is they all did. Kansas City built, sold to my grandmother, who lived in Independence, MO--home of the car till 1982. Then my cousin in Wichita--who didn't do anything to it, then me in 1988.
Not unlike the mythical starter shield.
That burlap is what's left. It was sandwiched in between, the middle of, 2 layers of rubber mat.
There is a shield/ pan that helps direct air to radiator and plugs the hole that would be there if something wasn't there.... Not sure that makes sense but that is what it does.... Tedd
#34
Actually, if you look closely, this is a good place to describe the spot where the apron goes. Look at the above picture. See the front of the cross member? The rubber apron goes between that, and the bottom of the lower radiator mount. It closes off that area between where the front engine mount is and the radiator support.
BeenThere
August 17th, 2018 01:17 PM
