Part number needed...
Old January 22nd, 2016, 12:05 PM
twintracks's Avatar
Hi All, I'm in need of the Delco Remy part number for the original 6 volt ignition coil for a '37 Olds L-37 Eight.
I have everything I need to install an original style ignition, and key in my '37 Olds, except the original coil. It takes a special coil with one terminal on the top (top since the coil goes in with the high voltage wire on the bottom), and one terminal on the bottom as usual next to the high voltage wire. The top wire comes from the key switch through a shielded tube supposedly to reduce radio noise.
I might have found a coil, but the guy needs a part number which I don't have. The car currently has a universal coil on it.
I'd really like to find, two to have a spare, since I drive the car, a lot.
Thanks, Jerry
twintracks is offline
Old January 22nd, 2016, 02:31 PM
BeenThere's Avatar
1937 Olds Coil
My 1948 and back Delco book shows part # 1115126. My 1956 and back Olds parts book shows Delco # 1915428.
BeenThere is offline
Old January 22nd, 2016, 06:18 PM
Rocketowner's Avatar
I just googled the part # 1115626 and it came up on www.nosandrestoredcadillacparts.com
And they have one listed for '46-'48 Cadillac for $180 and comes with attaching clamp and Delco Remy box. Hope this will help. Larry
Rocketowner is offline
Old January 22nd, 2016, 09:23 PM
Ozzie's Avatar
My 1955 Olds chassis parts book shows the same 1915428 number for 1937 & 1938 ALL. (group number 2.170)
Ozzie is offline
Old January 27th, 2016, 08:17 AM
Russ P in MD's Avatar
There's a NORS one on eBay for $75, NFI
http://www.ebay.com/itm/NORS-1935-40...NV~doa&vxp=mtr
Also saw aftermarket 6v ones at Rock Auto, starting around $11.51. Appears to be a pretty generic or widely used coil over many years, and should be easy to replace if you don't need factory/concours level.
Russ P in MD is offline
Old January 27th, 2016, 10:24 AM
twintracks's Avatar
Thanks Russ,
Yes the universal, generic coils are easy to come by. It's the bottom (top) terminals that make it a tougher fit.
I've got one coming, but I might pick up one of those from your link for a spare.
Thanks for the assist folks!!
Cheers, Jerry
Old January 27th, 2016, 09:47 PM
Andreas.Johansson's Avatar
Hi Jerry
If you want to spread your search Old Volvos like the 544 and 444 have a similar set up. But on your side of the pond they might be even more rare...
/ Andreas
Andreas.Johansson is offline
Old February 1st, 2016, 07:11 AM
garykrig's Avatar
The 1940 Master parts book Part No.1115126 Fits F37 to 40 G39 to 40 L37 to 40 List Price $3.25
garykrig is offline
Alg
January 1st, 2013 05:04 PM
joe_padavano
Brakes/Hydraulic Systems
February 28th, 2011 01:24 PM
deweirdt
July 21st, 2009 08:29 AM
harleyrules
December 5th, 2007 05:25 PM
Quick Reply: Part number needed...
