54 drum replacements
Old April 4th, 2019, 06:29 PM
Where can I get a set of new brake drums
johnreb49 is offline
Old April 4th, 2019, 07:19 PM
2blu442's Avatar
I don't know about new ones, but I've got some used ones if you can't find replacements that are new. If nobody comes up with a source for you let me know and I can dig out a pair to measure and see if they're still useable. I've got several sets but some are loose and some are on parts cars. John
2blu442 is offline
Old April 4th, 2019, 07:43 PM
Can your current ones be cut.
oldcutlass is online now
Old April 5th, 2019, 05:29 AM
okie88's Avatar
Fusick and Kanter carry reproductions.
okie88 is offline
Old April 5th, 2019, 06:42 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I would first try getting your current drums turned if possible and then getting some drums from John if he has some that can be turned. They will be better quality (not made in China) and probably cheaper. Just a reminder that your wheels on the left side are left handed threads.
redoldsman is online now
Old April 5th, 2019, 09:57 AM
Pics
Well here it is the passenger side had the what seems to be the original packed bearing and spindle compared to the driver's side with a sealed unit.
I prefer the sealed unit over the other plus the rotor on the passenger side has cracking inside.
I've had her for a year and spent time getting to know her and saving to upgrade all I could so I can get her out.
Old April 5th, 2019, 11:08 AM
Are the 49-52 drums the same as the 54?
Old April 5th, 2019, 11:50 AM
Ok learning curve
I thought that it was 2 different type drums but not the case .
The drum on the driver's side slid off but on the passenger side seized itself to the hub.
Either way I believe that I will put new shoes and some better drums and I'll be good.
Old April 5th, 2019, 01:09 PM
2blu442's Avatar
OK, this was the easiest one for me to reach. It came off a 1955 front axle, the tags on the car had expired in 1973 so it has been sitting for a while. Glenn, do you know if the 1954 and 55 drums interchange? Funny thing is I slid the drum/hub off the spindle and there were no brakes inside! It does look like the drum has been turned, but I don't see any numbers stamped into it saying what the maximum diameter is. For you vintage Olds guys on the site, what do you think? Can you see anything that would indicate this is turned too far, or OK to use? The inner bearing is the rollers, the outer bearing is sealed but there was no dust cover on it so the bearings likely need replaced. Let me know if you'd like to see close-ups of any areas. If this doesn't interchange I do have some 1954 drums, its just that this was the easiest one to get to and pull. John
2blu442 is offline
Old April 5th, 2019, 04:40 PM
There are kits to convert from the old ball bearings to tapered, which is why I asked.
Old April 5th, 2019, 06:09 PM
redoldsman's Avatar
John, I don't know for sure but I can't imagine the 54 and 55 drums are different. They did change to tube shocks in 55 but I doubt they changed the brakes drums. I just checked Kanter and they list the same brake drums for 52 to 58 and they are on sale for $89/each. You should be able to take the drums to any auto parts store that turns drums and they can tell you real quick if they can be turned. I did not see any brake drums listed with Fusick.
Glenn
Old April 5th, 2019, 06:32 PM
Phantom Phixer
Charlie Jones's Avatar
53 thru 56 front brake hub and drum assemblies are the same , almost .
53 thru 56 right hand drums are the same . 54 thru 56 left hand drums are the same , but the 1953 LH drums are a different number .
Check group 6.306 on this page ;
Charlie Jones is online now
Old April 5th, 2019, 07:01 PM
This may be something to look into if all the measurements are correct.
https://www.speedwaymotors.com/1947-...ion,24928.html
Old April 5th, 2019, 07:06 PM
Phantom Phixer
[QUOTE=2blu442;1165283] It does look like the drum has been turned, but I don't see any numbers stamped into it saying what the maximum diameter is. For you vintage Olds guys on the site, what do you think? Can you see anything that would indicate this is turned too far, or OK to use? /QUOTE]
Maximum drum diameters were not put on drums until some time in the late sixties or early ,seventies .
However , there is consensus among most machinists that a drum cannot be safely turned more than .090 oversize .
If your drums were originally 11 inches , the maximum diameter that they can be turned is 11.090 .
Old April 5th, 2019, 07:10 PM
It looks like they might have been turned a little, but there seems to be a lot of meat left. The object to turning drums is to take off the minimum amount of metal just to true them.
Old April 5th, 2019, 09:00 PM
redoldsman's Avatar
I am pretty sure machinist are regulated as to how much they can cut out of a drum.
Old April 5th, 2019, 11:29 PM
OLDSter Ralph's Avatar
They were probably turned originally, that's why they have a "machining step" Until you measure them accurately, its a guess. Cracking would be a problem. When drums go out of round, they become oval or egg shaped, possibly worn bigger. Either way, measuring size and out of roundness will clear up doubts. Its nice to know that "reproductions" are available. Tapered bearings would be a good idea.
OLDSter Ralph is offline
Old April 6th, 2019, 06:19 AM
Ozzie's Avatar
Hollander says 1954 - 1956 interchange on the front and 1952 - 1956 on the rear; whatever that may be worth.
Ozzie is offline
68 D88
February 11th, 2014 07:23 PM
Scott Hamel
September 12th, 2012 04:18 PM
SMILEYWATTZ
March 11th, 2012 10:05 PM
Aceshigh
April 14th, 2010 04:57 AM
Pfiffle
October 5th, 2009 04:32 AM
Quick Reply: 54 drum replacements
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
