53 Alignment
Old June 13th, 2018, 10:14 AM
Eightbanger's Avatar
53 Alignment
Guys, I don't have my maintenance manual, having my 53's alignment done next Tuesday, can anyone please post up the specs so I can give them to the man?
Cheers in advance.
Eightbanger is offline
Old June 16th, 2018, 01:03 AM
Ozzie's Avatar
Cheers in advance.
I don't have the 1953 Olds Shop Manual. Here's what's in the 1955 Olds Shop Manual:
Caster angle degrees**: 0 to -3/4
Camber degrees**: -3/4 to + 3/4
Toe-in: 1/16 inch to 1/8 inch
King pin inclination (at 0 degrees camber): 5 degrees 51' 10"
Toe-out: 23 degrees +/- 1/2 degree
Tread: 59 inches
**Maximum variation between the two sides of the car should not exceed 1/2 degree.
The first three specs. are the ones I usually use. I just put all of it in case you need it.
I have some old (non-Olds) books at the other house that may have the '53 specs in them. If I can find them, I'll re-post.
Ozzie is offline
Old June 16th, 2018, 01:18 AM
Ozzie, your a gent, much appreciated. I really hope this guy is able to do it, every other shop has said no when they actually get the car on the ramp.
Old June 16th, 2018, 08:19 AM
Ozzie's Avatar
I got lucky and found the old book. This is a Glenn's Auto Repair Manual from 1961 (a Chilton Publication). It goes back to 1949. These specs are given a bit differently from the ones I found before and are a little different from the '55. It says that 1949-53 are the same and 1954-56 are the same. Here's what it shows for 1949-53:
Caster degrees: N3/8
Camber degrees: P1/4
Steering axis inclination degrees: 4.5
Toe in (inches): 3/32
Toe out on turns (degrees): Inner wheel:20 degrees; Outer wheel: 23 degrees
I'm assuming that the N is for negative and the P is for positive. It doesn't show any "tolerance" range as did the Olds shop manual. But if all your components are without "play" (looseness), this should get you aligned.
Ozzie is offline
Old June 16th, 2018, 12:11 PM
Perfect! I'll post up if it's a success. Have a great weekend mate.
Old June 17th, 2018, 10:35 PM
Andreas.Johansson's Avatar
Hi I took a picture from my 53 manual.
/ Andreas
Andreas.Johansson is offline
Old June 18th, 2018, 02:03 AM
Thank you Andreas.
Downtown442
January 22nd, 2016 10:48 AM
neatolds
August 24th, 2015 11:57 PM
coldfire
August 23rd, 2013 03:05 PM
cutlass47
Suspension & Handling
October 2nd, 2012 06:39 PM
troberts6
January 7th, 2007 11:17 AM
Quick Reply: 53 Alignment
