Need a transmission!
My transmission went out on my 62 Dynamic. The bell housing is cracked. And pressure plates are cracked. Any suggestions where I can get a transmission or the housing? Or what can I do? Or if I can upgrade without a lot of fabrication?
If you're talking about the torsional damper, FATSCO transmissions should have it- they have some made every so often. Bellhousing- you talking about the adapter between engine and transmission? Used is your only option but 61-64 are the same and I won't swear one for an earlier 4-speed HMT won't work.
thomaswatk
April 7th, 2007 03:41 AM
WasteOfMind00
February 24th, 2007 10:14 PM
