1962 F85 Buzzing noise from transmission
Hello,
I have had my 62 F85 for just about 2 months and I have just started hearing a load buzzing noise coming from the automatic transmission. It does not always happen but it typically happens when I shift out of park. Sometimes it will go away when I put it to a different gear then back to drive or reverse. Other times it stays buzzing until the car starts moving.
Yesterday it happened and I put it back in park and the buzzing stayed on so I was able to locate the noise as coming from the transmission. Any ideas as to what is causing this and what should be done to fix it?
Thanks.
Thanks.
X2 on check fluid level. Roto HydraMatics are known to buzz when fluid is low. Probably pump cavitation from where it's trying to suck and pump air.
Yes the baby SlimJims were just as cantankerous as their big brothers.
Oldscutty72
March 3rd, 2014 07:30 PM
