Hurst shifter arm replacement 4 speed
Slide an .020 to .025 feeler gauge down the center of the shifter arm on the Drivers Side. It will be snug. When you are down about 3/4", pull straight up on the shifter handle. It should come right out.
Thanks. Shot it with blaster and put metal down the driver's side. No luck. I am going to try the razor blades on both sides next. I have bad feeling. My console shifter has a bolt hole and no detents. I can probably convert but already chromed it. One of those lost Saturdays. Thanks again.
67442nut
September 16th, 2017 01:23 PM
marxjunk
June 12th, 2014 12:34 PM
