Stuck axle bearing outer race???
Old January 15th, 2014, 11:39 AM
scooter123's Avatar
Hi guys I have my axels out but on the driver side the outer race is still in there....... It will spin in the housing and I can get it to move outward about 1/4 of a inch but then it stops !
I tried using a pick and work my way around bit by bit but its a no go
Can I use a bit of heat to get this sucker out??
scooter123 is offline
Old January 15th, 2014, 11:49 AM
Professur's Avatar
slide hammer
Professur is offline
Old January 15th, 2014, 01:00 PM
Trying to remember member
wmachine's Avatar
Originally Posted by Professur
slide hammer
Close, but if I understand him correctly just the outer race is in there and nothing to attach a slide hammer to.
Believe it or not, I had the *inside half* of the outer race stuck in the housing.
I used the claw of a standard claw hammer to get it out. The curve was just enough to get a tiny hold to work it out.
wmachine is offline
Old January 15th, 2014, 01:43 PM
Lansing built
1970cs's Avatar
A couple of things come to mind, if you have welder than cut a piece of key stock and lay it inside the race and weld it, let it cool and then use a slide hammer.
Stuff a rag inside the axle tube back far enough (metal shavings) that when you use a die grinder to grind the race thin enough and hit it with a chisel and hammer and break the race, you may have to do this on two sides and pry out the pieces.
Pat
1970cs is offline
Old January 20th, 2014, 09:53 AM
TexasT's Avatar
Call around to your local auto part purveyors. Many have a loan/rent a tool program. There is an attachment for a slide hammer that "folds", is inserted past the race, unfolded and the slide hammer can operate with it to remove the race.
You'll spent more time getting it rounded up than using it to get the race out.
TexasT is offline
Mr Shifty Sidney
November 10th, 2014 06:38 PM
warrior71
February 28th, 2014 07:52 AM
foo
Brakes/Hydraulic Systems
November 12th, 2012 06:41 AM
oldzy
Drivetrain/Differentials
March 3rd, 2011 07:15 PM
Flye
July 30th, 2009 10:24 AM
Quick Reply: Stuck axle bearing outer race???
