Rear end question!
Old November 7th, 2013, 03:02 PM
4Door67's Avatar
Rear end swap question
Posted in wrong spot I don't know how to delete, sorry.
So I have done a bunch of research about my "12 bolt" type O and its a pain to get parts if I can even get them at all with the certain model I have. I am looking for a rear end that can bolt in to my car that has aftermarket parts readily available. I have a 67 cutlass 4dr sedan (A body). What rear end/s should I look into and beef up?
4Door67 is offline
Old November 7th, 2013, 03:27 PM
car guy
gearheads78's Avatar
Any 64-72 A-body rear will bolt up. I like the 71-72 Olds, Buick corporate 8.5 10 bolt. Easy to find cheap and cheap common parts. I used 3.73 gears from a late model Suburban in mine.
gearheads78 is offline
Old November 7th, 2013, 03:31 PM
Does that require any driveshaft mods Richard?
oldcutlass is online now
Old November 7th, 2013, 03:34 PM
car guy
Not 100% sure on that. I had a custom 3" D/S made when I built mine since I was using a TKO 600 and planned future 550HP motor.
Old November 7th, 2013, 07:38 PM
507OLDS's Avatar
When switching from a 12-bolt O-axle,to a 71-72 8.5" 10-bolt,you will need to shorten your driveshaft. The 8.5" 10-bolt is hard to beat.They handle plenty if abuse,and everyone makes parts for them.
507OLDS is offline
Old November 7th, 2013, 09:56 PM
4Door67's Avatar
Is there any rear end that eliminates having to modify the driveshaft or is that the only route? If so do i have to get the stock one modded or do they sell one aftermarket. I guess a modded one thats welded just doesn't seem the strongest. Also what does the word "corporate" mean?
4Door67 is offline
Old November 8th, 2013, 12:56 AM
garys 68's Avatar
Getting a custom driveshaft is no big deal. By the time you pay to have yours modified, swap out the 40 year old U joints, scored and worn yoke, etc, you could buy new for not a lot more money.
http://southwestspeed.com/?sec=view_...ub=Driveshafts
garys 68 is offline
Old November 8th, 2013, 06:26 AM
Unless you just did that recently for T400 mod...
Old November 8th, 2013, 06:30 AM
car guy
To just shorten one check with any local offroad shops. Most of them are set up to do it.
Old November 8th, 2013, 06:32 AM
507OLDS's Avatar
You could install a 12-bolt Chevy,with the Canadian yoke,and leave the driveshaft alone. Same u-joint too. 3R.
Yes,if you swap from a Jetaway or Th350,to a TH400,you would also need to shorten the driveshaft or get a new one made.
507OLDS is offline
Old November 9th, 2013, 11:46 PM
4Door67's Avatar
What does corporate mean? and I have a re-built th350 with the short shaft, so it shouldn't need to be shortened correct? If i get a stock 10 bolt 8.5 can i put a 12 bolt carrier into it to change it over or is that not possible? And what is stock drive shaft length compared to new custom length with both 8.5 and th350(short shaft)?
4Door67 is offline
350TurBRO
September 12th, 2014 11:52 AM
72greensupreme
Drivetrain/Differentials
March 25th, 2009 06:13 AM
1964Jet*88
July 21st, 2008 05:26 PM
1964Jet*88
July 20th, 2008 09:05 AM
Good_Music_n_Cars
October 16th, 2007 07:35 PM
Quick Reply: Rear end question!
