Trouble with my HM350 !
Old October 13th, 2018, 07:43 AM
Lylosys's Avatar
Hello !
This afternoon I replaced the radiator on my 1973 delta 88 . No problem, but when I finished, and tried to drive, the transmission doesn't work anymore ! When I put Reverse, or Drive, nothing happen.
What Can it be ? I'm a little worried... Thank you !
Lylosys is offline
Old October 13th, 2018, 07:46 AM
Old School Olds
tru-blue 442's Avatar
Sounds like it may be low on fluid. Did you run it up to temp then check it?
tru-blue 442 is offline
Old October 13th, 2018, 07:55 AM
Lylosys's Avatar
It seems to be a little lower than minimal.
Maybe I loose some when I change the radiator.
If the level of fluid is too low, the transmission Can stop working like this ?
Lylosys is offline
Old October 13th, 2018, 08:21 AM
Old School Olds
Yes. You always lose some when replacing a radiator. Run it in park until the car is warmed up to operating temp.
In park at idle, check the fluid on the stick. You'll need to wipe it once, then re-insert to get the correct reading.
Old October 13th, 2018, 08:50 AM
Lylosys's Avatar
Thank you, it works ! I had ni idea a lack of fluid make the transmission completely stop working. Is it a security ?
Anyway, I just start the restauration of the car, I think it will not be the last question I will ask here ^^ Thanks a lot !
Lylosys is offline
Old October 13th, 2018, 09:02 AM
Old School Olds
You're Welcome. Good luck with it.
Old October 13th, 2018, 10:57 AM
It's the way automatic transmissions work. The "Hydramatic" in the name "Turbo Hydramatic" refers to hydraulic operation, which is using a pressurized fluid to move the internal operating parts. If the fluid level gets too low, there isn't sufficient fluid flow or pressure for the transmission to operate.
Fun71 is offline
Old October 13th, 2018, 12:38 PM
Lylosys's Avatar
Okay, good to know ! I still have much to learn :-) Thanks !
Lylosys is offline
Old October 13th, 2018, 12:52 PM
Keep an eye on it since you ran low on fluid it may have done some damage.
oldcutlass is offline
Old October 13th, 2018, 05:45 PM
If it stopped working after a radiator change it was probably pretty low to begin with. The cooler doesn’t hold very much fluid, less than a quart I would guess.
matt69olds is offline
Old October 13th, 2018, 08:32 PM
Unless some drained out of the cooler lines when they were disconnected from the radiator.
Fun71 is offline
plonka
December 12th, 2013 10:38 AM
oldsguybry
December 8th, 2012 08:15 PM
gardizzle
August 27th, 2012 09:20 AM
MudEye
July 8th, 2012 06:57 AM
ELECMAN
July 18th, 2011 03:00 AM
Quick Reply: Trouble with my HM350 !
