1997 88 4T60 E Napa filter kit
Old August 3rd, 2017, 04:07 PM
radioburningchrome's Avatar
Planning to do a pan drop as the oil cooler lines are leaking and will be replaced . Picked up this kit from Napa. Can someone tell me where the bushing in the center of the kit goes?
Have done filter changes on other vehicles, none were the 4T60.
radioburningchrome is offline
Old August 3rd, 2017, 04:39 PM
Old School Olds
tru-blue 442's Avatar
The filter pushes up into the valve body. The O ring slips over the tube
on your new filter. Make sure the old one comes off with the old filter.
If not, look up and pull it out with a pick or small screwdriver. There should
be 2 small bolts holding the filter up as well.
tru-blue 442 is online now
Old August 4th, 2017, 03:07 AM
Lansing built
1970cs's Avatar
Yes tru-blu has it right but the bushing acts like the old school oring. Same idea different setup. I did one on an 04 GP last summer. Had to get a piece of 1x6 flat wise to tap the filter far enough into place.
Pat
1970cs is offline
Old August 4th, 2017, 03:20 AM
Ok. Thanks
Pat
Thanks for the tip.
76 Regency
Brakes/Hydraulic Systems
April 10th, 2014 03:10 AM
RAMBOW
December 27th, 2013 06:48 PM
charlierogers
April 9th, 2013 09:07 AM
cfair
July 20th, 2012 09:10 AM
J-(Chicago)
May 26th, 2008 08:51 PM
Quick Reply: 1997 88 4T60 E Napa filter kit
