Will a 425 flywheel bolt to a 330
Old July 30th, 2017, 12:20 PM
Will a 425 flywheel bolt to a 330?
oldcutlass is offline
Old July 30th, 2017, 12:37 PM
Kennybill's Avatar
Yes, almost positive. 330, early 400's (B&E block) and all 425's, same flexplate & manual flywheel
Kennybill is offline
Old July 30th, 2017, 12:41 PM
Are 1967 330 HC cranks drilled for a pilot bearing.
Old July 30th, 2017, 05:04 PM
Kennybill's Avatar
I doubt it. Unless the vehicle was manual shift they weren't drilled for pilot bearing/input shaft. I just went through my stash of 425 engines/crankshafts looking for a drilled 425 crankshaft, 11, none drilled. I found a drilled 455 crankshaft in a Marine engine, plus like new flywheel. The machine shop I use will machine the crankshaft for around $100.
Old July 30th, 2017, 06:59 PM
Thanks for the info I could not remember.
Old July 31st, 2017, 05:57 AM
Oldsmaniac's Avatar
The 330 and 425 use the same bolt pattern on the crank and only factory stick engines had the cranks drilled for pilot bearing.
Oldsmaniac is offline
Old July 31st, 2017, 06:19 AM
Thanks for the info.
NAS Backyard
November 22nd, 2013 09:42 AM
Flye
July 28th, 2013 12:05 PM
therobski
March 14th, 2011 04:38 PM
DennisG.
October 29th, 2008 10:31 AM
Quick Reply: Will a 425 flywheel bolt to a 330
