455 & TH400 - High RPMs at cruising speeds
It doesn't seem right that my tach shows 3,500 RPM at 50 MPH. It is shifting to third, so I've kinda eliminated that as a problem.
Where do I start to figure this out? I read an old car magazine test that said I should be cruising at about 70 MPH at 3,500 RPM... I'm showing about 4,500 RPM at 60!
Had a friend pace me and my speedo is off about 3-4 mph at 50 (he indicated I was running 54). Can the tach be off too? Seems like a lot of R's for a BB..
Thanks for any suggestions...
It would not be the first time a tach is off, there are a multiple rpm formulas on the net that you can plug in your trans type, rear end gear, and tire size to come up with what your rpm should be at different speeds.
I'm having similar problems. I have a 67 Cutlass with a 400 engine, freshly rebuilt TH400 tranny and a 3:42 posi rear end. My tack is showing 5500 rpm at 55-60 mph. The tranny shifts twice, so starts in 1 shifts to 2, shifts to 3 however it shifts to 3rd very quickly. Can't figure it out.
BillJack
November 4th, 2015 04:15 AM
Arrowstorm
August 9th, 2015 04:27 AM
