1970 cutlass o type rear what to do??
I got a o type rear in a 70 cutlass open carrier with 2:56 gears. I was hoping to install a posi carrier and gears as I rebuild the car . Iam finding parts are hard to come by and only found one aftermarket vendor and that's pricey. I would like to keep the rear that came in the car and use it but may be a better option to find another rear end , maybe 71 or 72. Iam sure posters here have had this issue hopping to get some ideas on my issue . Thanks in advance???
Really kinda of depends if a good deal finds your way. Whether a better geared Type O or a 71-72 8.5 builder rear. I have bought 71-72 8.5 rears as cheap as $50 but it still usually a 2.56 open so not saving money at that point. Hang loose a search for deals on a 3.08-3.42 type O but also on the other 71-72 8.5 Skylark-Cutlass donor. At least with 8.5 the gears are super easy and cheap (late model 1500 series GM truck ) 80's,90's,2000's
Parts source
Talk to Jim at JD Race. He goes by Monzaz on here. He has helped many with rebuild parts for the 67-7O Type O and can give you info on other options like the 71-72 Corporate 10 bolt.
HitTheHole
Drivetrain/Differentials
February 4th, 2021 10:46 AM
L77F85
16
November 29th, 2013 06:19 AM
