Diff spider gear help
Took the axles ot of 1985 442 aand one of the differential spider gears fell out...no idea how. HOW do you put it back in when both axles are turning opposite directions? ARRGH.....any help is greatly appreciated...
Yes, it fell out easily....should I be taking the other ring gear out?....oops, I meant to say spider...good catch
ring gear? Hell no, if that spider fell out it can fall back in.
you do have to get both out or almost out, then start it [them] in, then turn one axle to "walk" the little gears in place at the same time.
Why was the spider gear shaft removed? Is this one of them type C designs?
smietana
November 3rd, 2013 12:07 PM
442garage
August 9th, 2013 07:13 AM
