Where can i find a replacement transmission?
Hey guys
My 1970 olds cutlass Transmission took a dump on me last year and I ended up selling the tranny out of it because it was no good But I realized I screwed up because I can’t seem to find another one anywhere.
I tried to buy one off of jegs and they ended up canceling my order after 5 month of waiting so I’m stumped, The car isn’t original at all someone put a Chevy 355 in it and the trans was a oldsTh350 short tail shaft that was adapter up to the block.
I’d love to get it back going again and I was wonder what aftermarket transmission would be a direct swap can I go with a Chevy th350 and it would boot Right up or would I need a olds trans because of how short the trans was Any help would be appreciated
Welcome.
The transmission needs to fit the engine family.
Your looking in the wrong places. Chevy transmissions fit Chevy engines. A transmission from a Olds will fit a Olds, in addition to a Pontiac and Buick. All things considered there are 3 times more BOP cores available than Chevy stuff.
It would help knowing what transmission you need. Th350? Th400? Short or long output shaft?
Find a core, any transmission shop worth a dime can build a decent 350/400 trans cheaper than buying one from summit or JEGS. Where are you located?
I have the short tail shaft i believe it’s really small and stubby and I measured it out to be about 6 inch where the yoke is. So would any tran th350 that had a short tail shaft in it work or is there a specific one?
because I had a truck th350 out of a 80s Square body with a short tail and it was a few inches off so I’m not that familiar with trans so is there a difference between car and truck transmission and that’s why it’s off or is it something else I think i have a pic of the original trans I’ll posted it below
68cutlassdriver
24
March 20th, 2021 04:33 AM
