Transmission lines from 200r4 to radiator
Hello All!
I am looking for recommendations on running steel lines from my 200r4 (built by DrDan, who did a great job!) to my 4 core aluminum aftermarket radiator. I do not have tools for dealing with putting lines together. I want as easy of a solution as is possible.
Right now I have rubber lines going to a trans cooler. I believe the installer put barb fittings on the rubber lines at the transmission. With your suggestions will you please include what fittings would need to accompany the lines?
Thanks!
Here's where they will be going:
Thanks!
Are your factory lines missing? The factory long nut lines TH350 bend quite easily to fit a 2004R's different angle, did it on my 70S. If not the 307 Cutlass lines should be close. I bet Dan did a great job on that trans, he knows those trans really well.
Thanks!
