TH 350 fluid problem
So my transmission for my 71 cutlass is acting very strange. Its been dumping out the fluid i put in it the past 3 times all within a week. I was wondering if there was anything that would prevent this? It doesnt look like its leaking but its coming out somehow. Maybe there a filter or screen in the transmission that pushing the fluid out? Please I need some advice to fix my car.
Check the grommet/O ring where the fill tube goes into the tranny. That could easily dry out over time. I had a similar situation a year ago. After I pulled the fill tube out and put a rubber O ring on the end, my problem was fixed.
Guest
Posts: n/a
TH350 fluid problem
Hi . I had a similar problem with my 68 olds 98 with a TH400 ,but mine was leaking onto the floor of garage it was completly rebuilt when i did a nuts and bolts frame off restoration ,I would check it for the source of leak couldnt find it ,finialy replaced the modulator valve solved the problem ,only thing i can think is the vacum was sucking or pushing the fluid out .
rocwal
Dan B
rocwal
Dan B
rocwal
Dan B
rocwal
Dan B
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
jaco
January 19th, 2007 09:09 PM
