Jetstar 700r4
Old April 3rd, 2017, 09:33 PM
  #41
cjsdad's Avatar
Originally Posted by 330jetstar
Is this the right bolt pattern trans for my 330
Attachment 149390
That is a dual pattern bell housing so it will fit your 330. You can set it next to the trans you remove and mark the holes you will need to use to attach it to the engine so you are not trying to stab bolts into a blind hole while installing it.
Use the search function to read as much as you can about the 200-4r install. You will be able to find the answer to most any question you have. Even if you ask the same questions again, someone should answer you.
cjsdad is offline
Old April 16th, 2017, 08:07 AM
  #42
330jetstar's Avatar
Finally found and picked one up yesterday.
History is unknown so I will price out rebuilds.
330jetstar is offline
Old April 17th, 2017, 06:20 AM
  #43
Let us know when you get it rebuilt. Plus, post some pics, stat!
Olds64 is offline
Old April 17th, 2017, 10:22 AM
  #44
TexasT's Avatar
you want to be sure who ever does the build is familiar with the 2004r and isn't just the local place that builds "the best racing transmissions". Ask for some references and follow up on em. These require some attention to detail and the clearances must be followed or you will be disappointed with the final product.
TexasT is offline
TOONLOVESCHERYL
February 4th, 2016 06:30 AM
64starfire
June 10th, 2009 06:51 AM
projectheaven
May 18th, 2009 05:20 AM
64starfire
April 22nd, 2009 01:00 PM
Jolly Green
February 25th, 2009 07:25 AM
Quick Reply: Jetstar 700r4
