Bought 1967 M20--need some small parts
Good morning. I finally found what looks to be a nice Muncie M20. I am going to need some small parts. Seals, front collar where the throw-out bearing sits. Can anyone recommend a seller of Muncie small parts?
Also the output shaft has 27 splines. Will my TH350 yoke fit this?
I don't thing the BM shifter is going to work. Not sure about the shift rods. Where is a good place to buy these parts?
I will post pictures of the shifter and shift rods to get some input.
Also going to need an Olds bell housing if anyone has one.
Thank you.
David
Thank you.
David
The Turbo 350 yoke should fit your Muncie, the driveshaft too. The Muncie and the Turbo 350 are the same length. What shifter do you have? There aren't many choices besides Hurst which stocks everything or you can get it off eBay and send it to them to be rebuilt and wait awhile to get it back. Back in the day there was also Mr. Gasket but I don't see those around much any longer. The bell housing is Buick Olds Pontiac, all the same. Lots on eBay or you can buy new reproduction.
Check out Supercars Unlimited. They are very knowledgeable about our Oldsmobiles. They will have what you need and are a reputable outfit. Their trans stuff is at this link.
Happy Motoring!
Happy Motoring!
5speeds.com
kajonjon.com
Are two good ones.
kingme777
June 1st, 2015 10:34 AM
cheffernan
October 13th, 2012 05:38 PM
louisianaboy05
February 10th, 2009 03:26 PM
