72 cutlass t350 overhearing
Hey what’s up guys. I recently drove my 72 cutlass from Dallas to okc ( I was scared shitless) I made it all the way to the border and my trans started like downshifting and what not so I exited right at the red river and let it cool down cuz I checked the fluid it was all good and full. I got gas then got back on the road. Then it started doing the same after 30 mins of driving. It’s a new tci I we put on just before I left for college. Basically I had to stop every 30-45 mins because the trans would overheat and downshift. I’m just wondering if I should get a trans cooler since it only happens when I’m driving on 3rd gear for an extended period of time. If so can u guys recommend which type and which brand. If not let me know what I should do.
No. You already have a transmission cooler at the bottom of your radiator which is nominally designed to cool your ATF. You do not need nor do you want to add a separate dedicated transmission cooler. You only need to resolve the issue you are having.
Agreed that there is already a trans cooler and an external may not be needed. Minor technical point, the trans cooler is on the right (passenger) side of the radiator and not the bottom. You can see it if you look in the filler neck on a radiator that's empty or has very low coolant level.
I hear ya about so many vehicles you lose track of which one has what. The trans cooler on the replacement radiator that I just installed in my Jeep Wrangler is on the bottom as well (even though it has a manual trans - universal part to fit all applications). The main reason why the trans cooler location on the Cutlass is burned into my brain is mine leaked after getting the radiator rebuilt and having to bring it back to the radiator shop to have the cooler replaced, so I saw the radiator disassembled with the cooler exposed.
If it was running properly at cruising speed I wouldn't suggest this - because it wouldn't be the transmission vacuum modulator correct? But, since it is not operating correctly at cruising speed, it does lend itself to the possibility the vacuum ATM (automatic transmission modulator) is suspect or a vacuum hose on the TVS assembly? JS
Do you have the 1972 CSM? Check out the location of the ATM valve on the transmission - any oil leaking from it? Is the vacuum hose securely attached to the ATM valve? Trace the vacuum hoses on the TVS (DVCS) assembly - ensure they're all securely attached. Ensure the electrical wire harness at the top of the TVS solenoid is secure.
You've got a failed transmission.
At best, the filter is plugged. Shutting the engine off allows some of the sediment plugging the filter to fall to the bottom of the pan. Depending on what the sediment is, MAYBE you could replace the filter and be OK. (Not likely. Possible.)
At worst, the filter is plugged because the clutches are coming apart.
