350 turbo stall converter question???
I have a Olds 350 turbo trans and have found good deals on quite a few chevy stall converters... so my question is will one of these chevy stall converters work with my Olds tranny? is it compatible?
All TH350 and TH400 converters interchange (except for the switch pitch TH400s from 65-67).
This is a good question. Summit sells numerous torque converters under their "house brand." Unfortunately, they are only listed under Chevy on their website. Check it out:
http://www.summitracing.com/search/D...t/?Ns=Rank|Asc
The only issue I have ever come across is that an "Olds" converter has a threaded boss where the "Chevy" converter requires a nut and bolt. You may have to clearance the flywheel weight a tad or use a spacer, but no biggie either way.
stlregal
November 17th, 2010 04:54 PM
