200 r4 transmission identification????
Originally Posted by turbobuicks.com
I show the HTF code is from a 87 G-body, Canadian spec SBC 305 car.
Wondering if the valve body is just standard or a step up.
The only information I can find, the 200 4r from 87 has the hardened sun shell and a couple of other parts. Not sure if this is true at all.
I picked up a similar 87 2004R in front of a 73 350 with 83 307, intake, carb and manifolds. The later the trans, the more improvements. If you are planning on rebuilding behind power everything needs replacing anyways. Expect soft shifts and 4000 rpm full throttle shifts.
A good shift kit and servo like ones from CK will make it similar to the 442 valve body, firm and later part throttle shift points. I get 5000 rpm full throttle shifts modding the regular 4000 rpm governor. It is actually better because I stake the spring in the small weight.
