200 4R Tranny Issue
200 4R Tranny Issue
My tranny sounds like marbles in 1st gear and into second gear for a bit. Then issues started to happen when backing up. It feels as if the tranny is trying lock up or something is grabbing . This happens in neutral when you try to move it backwards. Verified the aniti-slip / diff is good with the drive shaft removed.. wasn't sure at first.
Possible sprag clutch issue or something else??? After it goes into 3rd and over drive, there are no issues.
I guess I will pulling the tranny and dropping it off at the rebuilders. I'm putting on a different pan with a plug in it for the oil drain... What a pain it is.
