1976 Cutlass Transmission Problem
I have a 1976 Cutlass Supreme with 350 combo. I am having problems with shifting into 3rd gear. It shifts perfectly into second. I can downshift from D to 2 but nothing from 2 to 1. I bought the car with a aftermarket B&M floor shifter ( was originally column ) the floor shifter reads P R N D 2 1. The kickdown cable has been bypassed. Curious to know if anyone has had the same problem or some advice on what to check for
Are you saying that the shifter physically won't go into first gear position OR the shifter will go into the correct position and the transmission doesn't shift accordingly?
Can you count and feel each detent of
P R N D 2 1 ? I'm thinking and hoping it is a shifter adjustment issue.
Is it definitely a TH350?
Good luck!
Good luck!
Good luck!
Good luck!
And yes it is a TH350.
I can go they the gears while parked all P R N D 2 1 but once driving in D I only feel and hear the car detent from D to 2. I can still detent manually into 1 but nothing will happen
Good luck!
Good luck!
fast442
November 25th, 2019 08:05 AM
JOHNNYOLDS442
September 27th, 2015 06:23 PM
