1965 4 speed shifter
Hey I'm looking for some help. I have a 65 442 with a 4 speed and still original to the car. My problem is the shifter is horribly loose, is there anybody out there that rebuilds these? I don't know what brand oldsmobile used back then if its a Saginaw or a hurst or what ever. Any help is greatly well come
Hurst used to rebuild the older Munice/ Mr. Gasket shifters years ago and they stopped. There are few re-builders to check out, one of them is:
https://www.shifterdoc.com/productca...hifter-d17.htm
If all else fails or you want to install a different shifter: I have a 70-80's vintage Mr. Gasket shifter in excellent condition that was re-bulit by Hurst/Mr. Gasket years ago and never used it.
Hi,
Muncie style shifters all seem to have extra play, the unit itself was used by Buick, Oldsmobile and Chevy so you might be able to find a tighter one, also there might be someone making reproductions especially if for a Chevy lol.
I know you can try to rebuild yourself, may need to weld up any grooves or rust pits, and might be possible to shim up the play to a extent.
Regards,
Regards,
Hey guys rather having my piece of garbage Muncie shifter rebuilt and still end up with less than satisfactory, I went out and bought a new Hurst Comp Shifter and linkage. Plus I bought the "t" adapter to put my original handle back on. I have a Consul in my car. I installed every thing but now the base of the handle and the top of the "T" hits the consul going into 2nd or 4th not allowing Trans. to go into gear. Has anybody else had this problem? I see really only two fixes, fab up my own off set "T" or cut off the mounting base on handle,weld an extension on and get it re-chromed. Looking for help.
