1991 Trofeo' Gear Selector Indicator Housing
Took apart the center column to get to the gear selector indicator housing. I Found the orange painted indicator was completely broken off the connection to the slide material around the gear shaft. Only one half of the shattered 2 tipped connector was found inside the gear selector housing. On the housing case I had to shear off all the plastic rivets holding it together. The other great contortion adventure was the screws that hold the housing around the gear shift are (4) 1/4" hex head bolts you have to blindly feel for and remove because they are underneath the bracket around the gear shift (I lost a 1/4" hex bit that fell into a "never to be seen again" hole inside the bottom of the center column) I've done a search on the net and found nothing for a complete gear selector housing replacement. I'll have to find one in a junkyard and see if the selector is somewhat more intact, or try to glue and create a fix this one for now. This is probably a hard part to find.
