Need help pulling engine in 1966 Toronado. Something is hanging up!
Old October 13th, 2012, 03:55 PM
nj_cutlass72's Avatar
guys, i need help!
i am pulling the engine out but it wont come out.
the flywheel comes apart, engine block from trans separates but it wont let go. the front part of engine lifts off but
something is not letting go.
i need an expert to pin point what im missing,
the flywheel had 3 bolts which i unscrewed already.
nj_cutlass72 is offline
Old October 13th, 2012, 03:57 PM
i can call if you pm your #
Old October 14th, 2012, 05:19 AM
66eltoro's Avatar
Did you remove to bolt under the power steering pump that attaches the engine to the diferential?
66eltoro is offline
Old October 14th, 2012, 11:11 AM
there were 2 bolts on passenger side, and 2 on drriver right under the power steering pump, those are accounted for.
perhaps the axle thats below the oil pan is the problem, so ill take that off, i hope its not too difficult to do.
thx
Old October 14th, 2012, 11:34 AM
2blu442's Avatar
I think you had to remove the inspection cover to get to the torque converter to flexplate bolts, but just in case did you remove this piece?
2blu442 is online now
Old October 14th, 2012, 11:47 AM
2blu442's Avatar
thx
If these suggestions don't resolve your problem let me know and I'll cut out these posts to create a new thread. Yeah, without thinking about it we've hijacked Chris's thread and you may be missing replies that others could give if you had a new thread.
John
Old October 14th, 2012, 08:24 PM
John
hey John,
Good idea to cut and move to a new post, sorry Chris.
I did remove the cover and it was not so easy to get that one bolt tucked all the way inside where I had to use alot of extension to reach in from the drivers side.
Old October 14th, 2012, 09:20 PM
2blu442's Avatar
So the front is lifting up but its hanging in the rear? Are you getting it high enough for the rear of the oil pan to clear the crossmember? I've pulled a couple of these just the engine and then engine/transaxle together and remember it's a bear either way. Maybe someone else will have a suggestion of what you can look for.
John
Old October 14th, 2012, 09:26 PM
RROLDSX's Avatar
Ground strap?
RROLDSX is offline
Old October 19th, 2012, 05:14 PM
2blu442's Avatar
nj did you get it resolved? If so would you post what the hangup was? That may help someone in the future having the same problem.
John
Old October 19th, 2012, 06:27 PM
The_Jeremiah's Avatar
I had this problem once, it was the flywheel stuck to the converter. broke the bellhousing getting it apart, oops but it did come out
The_Jeremiah is offline
Old October 19th, 2012, 08:19 PM
i havent been back at it yet, the car is at my in laws and ive been busy at work.
will definitely update blog once i figure things out.
Ed
Old October 20th, 2012, 07:13 AM
66eltoro's Avatar
It sounds like you have everything unbolted. It usually takes some hard lifting and shaking to get the dowels that align the engine and trans to seperate. It is tight between the oil pan and the right drive axel, but you don't have to remove the axel to get the engine out or in.
66eltoro is offline
Old October 20th, 2012, 07:32 AM
TripDeuces's Avatar
Is the engine moving forward enough to clear the alignment dowels on the transmission case? Also do you have all three engine mounts removed, one on each side of the engine and one in the front attached to timing cover?
TripDeuces is offline
Old October 20th, 2012, 06:49 PM
so finally
I was able to get the engine out...
Tip for a rookie like me that may attempt this:
- after you've done everything, made sure all bolts/nuts/covers, etc.. are off..
- during the pulling the engine out with hoise, use a jack to the lift the trans first!
The issue with me was the transaxle was holding the engine down so once that cleared, it came right out.
thanks all
Old October 21st, 2012, 12:00 AM
I love the toro's so much, one of these days I would like to have a toronado to drag race
Old October 21st, 2012, 12:52 PM
Oldsdruid
rocketraider's Avatar
Like this?
http://www.breznick.com/toronado/wheels/W-150-2.jpg
http://dragracingonline.com/columns/...es/tornado.jpg
rocketraider is online now
Old October 21st, 2012, 02:09 PM
thats originally what made me want to drag a toro yes, I love the terrifying toronado, 2 supercharged 425's! yes!, too bad theres not more media on it
Old October 21st, 2012, 10:08 PM
Oldsdruid
To quote Joe Schubeck "Hairy went where Hairy wanted to go".
The Terrifying Toronado suffered from the same ill handling as Hairy. If you've seen the steering linkage on an early Toro you know it's pretty stout. Under full throttle, both Hairy and the TT would toe the front wheels in so hard it would bend the Toronado tie rods. There was all kinds of reinforcing done to the steering linkage to get the cars to where they were even remotely easy to control.
You ready for all that, my Jeremiah friend?
Daniel Marsh
August 5th, 2014 07:10 PM
lemoldsnut
February 10th, 2013 10:00 AM
nj_cutlass72
October 2nd, 2012 08:42 PM
christine fury
June 6th, 2009 06:21 PM
ztim
March 14th, 2007 12:37 PM
Quick Reply: Need help pulling engine in 1966 Toronado. Something is hanging up!
