1983 Toronado Transaxle
Old August 28th, 2018, 05:34 PM
ves007's Avatar
Does anyone know who to get a hold of for a ring and pinion. GM made a 315 and 336. Any help would be great.
ves007 is offline
Old August 28th, 2018, 07:07 PM
72 Olds CS
RetroRanger's Avatar
I dont know but one person to try is Monzaz on this site he has some great knowledge of olds rear ends and maybe he has some of the front ends too !!
RetroRanger is offline
Old August 29th, 2018, 06:38 AM
The GMC motorhome community is probably a better source for different final drive gears, but be sitting down when you ask about the prices. Those RVs used the older TH425 transaxle. I don't know how the TH325 gears compare. There is also an aftermarket limited slip differential. The manufacturer thinks very highly of it.
joe_padavano is offline
Old August 29th, 2018, 01:49 PM
ves007's Avatar
Thanks Retro Ranger and Joe
ves007 is offline
Old August 30th, 2018, 01:36 PM
BillK's Avatar
They actually made quite few different ratios for 83. I have a list at home. Will try to take a picture of it tonight. I have actually seen NOS ones on e-bay but they were very pricy.
BillK is online now
Old August 30th, 2018, 01:52 PM
Surprisingly, more that I would have imagined. For the 1982-85 cars, the parts book shows four available gear sets.
RPO F47 2.73:1
RPO F45 2.93:1
RPO F57 3.15:1
RPO FW4 3.36:1
Old August 30th, 2018, 02:22 PM
ves007's Avatar
Thanks Joe
All of the gear sets are discontinued through GM. Called all gear manufactures and no go.Someone has to have one or two of these just sitting around. Still not giving up,
ves007 is offline
Old August 30th, 2018, 02:44 PM
ves007's Avatar
Thank Bill
Called up advanced automotive group. He said maybe but he needs drawings of the ring and pinion. They are a CNC machine shop. I tried advanced automotive machine but no one there, try again later.
ves007 is offline
Old August 30th, 2018, 06:09 PM
BillK's Avatar
Joe beat me to it Mine also shows a 3.36 gear set 1625764
BillK is online now
Old September 19th, 2018, 06:53 PM
Big Daddy No Bucks
ThePackRat's Avatar
I sought out this info years ago.
According to the Rivi peeps from the Turbo Buick sites :
3.36's were supposed to be stock on the 83/84 turbo Rivs with the 85 turbo Rivs getting 3.15's.
3.15's should also be in the 4.1 Eldo & Seville 82-85 which should be easier to find.
Its a shame these or even steeper gears weren't more readily available.
A stock tire height E-Body loses some of the benefit of a better gear vs a stock tire height A/G body.
I always believed the 3.73's in the VIN 9 307 Hurst/442s had much more of an effect on acceleration than the different torque converter - carb - distributor & the "Y" pipe dual outlets did.
There's a twisted part of me that would love to see a regular Y 307 Cutlass with nothing more than 3.73's go up against a VIN 9 Cutlai just for gits & shiggles.
ThePackRat is offline
Ronschwartzsr
July 14th, 2014 05:27 AM
RATCHETMASTER
July 10th, 2013 02:29 PM
swimmster
April 27th, 2013 01:49 PM
shakeyhands73442
January 13th, 2013 12:39 PM
brian j combs
August 10th, 2007 09:34 PM
Quick Reply: 1983 Toronado Transaxle
