1991 Trofeo' Gear Selector Indicator Housing
Old March 13th, 2015, 07:14 PM
DeepBlue91's Avatar
Took apart the center column to get to the gear selector indicator housing. I Found the orange painted indicator was completely broken off the connection to the slide material around the gear shaft. Only one half of the shattered 2 tipped connector was found inside the gear selector housing. On the housing case I had to shear off all the plastic rivets holding it together. The other great contortion adventure was the screws that hold the housing around the gear shift are (4) 1/4" hex head bolts you have to blindly feel for and remove because they are underneath the bracket around the gear shift (I lost a 1/4" hex bit that fell into a "never to be seen again" hole inside the bottom of the center column) I've done a search on the net and found nothing for a complete gear selector housing replacement. I'll have to find one in a junkyard and see if the selector is somewhat more intact, or try to glue and create a fix this one for now. This is probably a hard part to find.
DeepBlue91 is offline
VI Cutty
October 4th, 2014 12:02 PM
Eli 72
March 30th, 2014 01:16 AM
Redog
July 20th, 2011 03:37 PM
FATRATMATT
October 16th, 2008 04:21 AM
carnell71075
November 21st, 2007 03:26 AM
Quick Reply: 1991 Trofeo' Gear Selector Indicator Housing
