mysterious misfire - ClassicOldsmobile.com
Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
mysterious misfire
Old October 29th, 2014, 10:33 PM
mysterious misfire
1995 Oldsmobile 3.4 l V-6 Mysterious misfire. Started intermittent. new plugs, wires coil pack, camshaft positioning sensor, now no codes or check engine light but runs on 5 cylinders and four when on the highway unless I back of on accelerator. Number 1 cylinder has no spark but coil pack seem ok Lost for options to try
tim
summertimeblues is offline
Old October 30th, 2014, 02:04 AM
'87 Delta 88 Royale
rustyroger's Avatar
It's entirely possible some of your new parts may be faulty.
First job is to trace back to why you have no spark at #1. Substitute the plug, then the wire, then the coil pack, unless the coil pack has a faulty supply it can only be one of these three. Do it one at a time or you won't know which is the faulty item.
Before you start taking things off, if you can lift the hood and run the engine in the dark, this will show up any tracking, that is arcing between the coils and the plugs. if you see this phenomenon you will save yourself some work because you will have identified the fault.
Welcome to CO btw.
Roger.
rustyroger is offline
Old October 30th, 2014, 05:57 AM
72 Cutlass Supreme
gs72's Avatar
Here is a pretty good article on diagnosing this type of ign. Sys.
http://easyautodiagnostics.com/gm/3....l-pack-tests-1
gs72 is offline
Old October 30th, 2014, 07:08 AM
No power to the #1 plug would suggest a fault,with the coil pac you replaced. Put the old one back on and see if that changes the situation. Replacing everything all at once makes diagnosis harder to do.
Allan R is offline
Old October 31st, 2014, 04:57 PM
Thank you so much guys. Finding the problem in the spark plug wire
Cutlass455
August 7th, 2015 04:28 PM
72cuttys
July 14th, 2014 08:00 AM
oldsmoguy
April 22nd, 2014 08:33 PM
HiCompOlds
May 8th, 2012 10:58 AM
haha
December 6th, 2009 03:37 PM
Quick Reply: mysterious misfire
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
