Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
top won't line up
Old November 11th, 2013, 08:43 AM
RickH's Avatar
top won't line up
I've got a '72 Cutlass Supreme convertible. When putting the top up, I have to literally wrestle the top to get the pin into the hole in the window frame on the driver's side. With a lot of grunting and groaning on my part, I can finally get it to go in and then clamp it shut quickly. There is no way that my wife can exert enough pressure to get that pin to go in where it should. I know that it should be easier than this.
Is there some sort of an adjustment somewhere that would help get rid of this problem?
RickH is offline
Old November 11th, 2013, 08:59 AM
NHolds's Avatar
Too far away, or too far left or right?
NHolds is offline
Old November 11th, 2013, 09:08 AM
Octania's Avatar
I think the front bow or cross piece is adjustable
of course that will require a bit more vinyl, which becomes a headache quickly.
consult the body manual?
Octania is offline
Old November 11th, 2013, 09:36 AM
RickH's Avatar
Too far away
RickH is offline
Old November 11th, 2013, 09:48 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
If your not the handy type or dont want to tackle this find a good auto interior shop. It will likely take them 30 minutes and cost you $30
droldsmorland is offline
Old November 11th, 2013, 10:20 AM
71 cutlass convertible
lshlsh2's Avatar
Has it been down for a long time? Is it cold when you are putting up? I know with mine if I leave it down for a long time and it is cold when I'm trying to put it up it is a real pain. If I put it up and down in the summer it is alot easier. Just some thoughts.
Larry
lshlsh2 is online now
Old November 11th, 2013, 10:39 AM
teqdave's Avatar
I just put mine up yesterday and had the same problem. I have wrestled with mine for years since I took out the top motor. Like lshlsh2 said, it largely depends on how often you put the top up. What I am doing is letting the top "relax" for a day or two and then I will connect the latch on the driver's side (with some effort).
teqdave is offline
Old November 11th, 2013, 11:18 AM
Mine has a dark [blue] top so it heats up quicker. I raise the top as far as it willl go, park the car in the sun with the windows up and turn on the heater. It makes the wresteling match easier
The craziest things about 69's 442 is they have 2 holes above the windshield but only 1 pin
Jamesbo is online now
stevengerard
September 10th, 2014 03:17 PM
eazy
July 1st, 2013 08:36 PM
davepnola
December 2nd, 2010 09:00 PM
Flye
July 31st, 2009 04:03 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: top won't line up
