Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
NOS or not?????
Old July 12th, 2012, 04:37 PM
My442's Avatar
NOS or not?????
I bought this OAI vacuum motor on e-Bay.
The original box says P/N 406424.
It has a 1978 date code ink stamped on the bottom.
I have never seen one like this.
Opinions?
My442 is offline
Old July 12th, 2012, 06:41 PM
It does look different from the ones sold by Thornton. Slight variations though. Did yours come in a GM box?
Thornton OAI vacuum motor
I don't know enough about the OAI vacuum motors to tell you for sure if it's repro or NOS. The pull tang on the motor doesn't look like any of the ones I've seen on OAI searches though.
Even the ones from Parts Place and OPGI look slightly more like the one from Thornton
I'm sure someone with an original OAI setup will be able to solve the riddle.
Allan R is offline
Old July 12th, 2012, 07:47 PM
Oldsdruid
rocketraider's Avatar
406424 is the part # listed in the 1974 parts book.
I have a 1987 Parts History catalog showing it was discontinued sometime between June 1982 and June 1987, so a 1978 production date would put it current for just prior to being discontinued.
I expect it was substituted or superseded by another part #, and that is what you have. Even though it doesn't look exactly right, it probably "fits and functions" correctly. Probably a TransAM shaker door actuator, and as many of those as I fooled with I cannot remember what they look like.
rocketraider is offline
Old July 13th, 2012, 11:44 AM
I looked in the 72 Olds parts manual. What did you use as your search? I Tried motor, vacuum, OAI but couldn't find it. I also have an 83 manual I can check to see if the changeup part number shows there.
Allan R is offline
Old July 13th, 2012, 11:55 AM
"Car"mudgeon
GAOldsman's Avatar
Try OAI Vacuum motor
GAOldsman is offline
Old July 13th, 2012, 12:12 PM
Still can't find it even using that. Checked the alpha index too. I've tried all the combos. What group is this under?
Allan R is offline
Old July 13th, 2012, 12:15 PM
My442's Avatar
Group 3.415
My442 is offline
Old July 13th, 2012, 12:36 PM
Thanks. Found it. The index was calling it a (motor, carburetor air cleaner) which I thought was the vacuum for the hot air sensor in the air cleaner controlling the heat from the stove pipe to exhaust manifold.
I'm sure GM parts counter people had to take a specialized course to figure some of this stuff out. Appreciate your help with the reference.
I bet it cost more than the $4.36 it lists for in 72! The part number is the same in the 83 catalogue, but the price jumped to a whopping $13.50
Allan R is offline
Old December 30th, 2013, 05:22 PM
rarerallye350's Avatar
Originally Posted by joesw31
I have seen this motor on ebay many times, it is original, but appears to be defective to where the lever is rivited to the diaphragm.
I know the guy who was selling this on ebay It is a real NOS part. New in box. I know when and where it was bought.
rarerallye350 is offline
Tom442
March 20th, 2022 06:20 PM
jensenracing77
May 29th, 2015 01:20 PM
coppercutlass
March 2nd, 2015 02:49 AM
67442nut
October 28th, 2010 09:22 PM
Allan R
June 5th, 2009 11:20 AM
Quick Reply: NOS or not?????
