Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Stubborn seal
Old May 29th, 2012, 07:28 PM
FAZ442's Avatar
Stubborn seal
I am currently working on replacing the bottom seal on my steering gear box. After an hour of trying to take off the pitman arm I thought it would be smooth sailing from there until I got to the seal.
Does anyone have any tricks or suggestions on how to take off this seal? I already tried using two screws and pulling on them but it didnt work to well.
FAZ442 is offline
Old May 30th, 2012, 04:56 AM
72 Olds CS
RetroRanger's Avatar
I have read that you should remove any retainers and then turn the steering wheel side to side w the engine running and the seal will pop out. I have never tried that, but it sounds feasible
RetroRanger is offline
Old May 30th, 2012, 05:48 AM
Lansing built
1970cs's Avatar
seal
http://wildaboutcarsonline.com/membe..._Section_9.pdf
See if this helps! I am assuming that your are doing this on the car?
If you are you may be able to wedge a flat tip screwdriver between seal and housing and partial collapse seal and pry it out. Then make a trip to the hardware and get a schedule 40 chunk of pvc long enough to go beyond the
shaft length, and match to just in side of o.d. of seal for a driver, only unless you have something hangin around that will do the job.
Pat
1970cs is offline
Old May 30th, 2012, 06:55 AM
FAZ442's Avatar
Would the pump have to be full in order for it to build enough pressure? Sounds like this method could make a mess but at this point I dont care.
FAZ442 is offline
Old May 30th, 2012, 06:58 AM
FAZ442's Avatar
70 cs .... I think its probably going to come down to your method though.
Thanks for that link... It is extremely helpful and detailed. Do you know if they make similar ones for other car parts, such as engine, a/c, transmission?
FAZ442 is offline
Old May 30th, 2012, 08:07 AM
Lansing built
1970cs's Avatar
question
If you were refering to more of the service manual? Yes, join wildaboutcars.com and you will have access to all kinds of manuals and brochures and it's FREE!
Pat
1970cs is offline
Old May 30th, 2012, 10:04 AM
The trick to removing this seal without the Kent Moore tools is to drill a series of small holes in the exposed metal part of the seal around the pitman shaft. Use grease on the drill bit to capture the chips. Thread a sheet metal screw into each one of the holes and use the screws as points to pry on to remove the seal.
joe_padavano is offline
Old May 30th, 2012, 10:40 AM
ELY442's Avatar
That's how i do it. When you get the pitman arm off, there's a retainer clip in front of the seal. Remove the clip. Put the pitman arm back on with the nut finger tight. Place a drain pan under the arm. Make sure you have plenty of power steering fluid in the reservoir. Start the car and turn the wheel all the way until it locks. The seal should pop off.
ELY442 is offline
and1stp
November 4th, 2023 07:42 AM
SkylinesSuck
March 5th, 2015 07:06 AM
yeahbuddy
Body work
March 16th, 2010 07:21 PM
Wes
August 21st, 2006 01:26 PM
Sixoh
August 8th, 2006 05:11 AM
Quick Reply: Stubborn seal
