Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
olds transmission
Old August 18th, 2011, 02:51 PM
dartphil's Avatar
olds transmission
=Are all gm transmissions the same bolt pattern? I have a 64 330 olds with the st 300 that is slipping in drive. So i think i want to replace it with a 350 turbo. I guess i will need some linkage for the kickdown then also? Thanks Phil
dartphil is offline
Old August 18th, 2011, 03:12 PM
Oldsmaniac's Avatar
Yes Yes.... The Buick Pontiac Olds Cadillac share the same bellhousing/trans mounting pattern.
Oldsmaniac is offline
Old August 18th, 2011, 03:14 PM
dartphil's Avatar
but what about chevy bolt pattern will they also fit?
dartphil is offline
Old August 18th, 2011, 03:21 PM
Oldsmaniac's Avatar
no
Old August 18th, 2011, 03:23 PM
dartphil's Avatar
Thumbs up
Thanks I just scored me a good 350 turbo from a buick so all is well then.
dartphil is offline
Pookster6
January 14th, 2016 02:29 AM
Pookster6
October 31st, 2011 11:52 AM
mikey0560
October 14th, 2007 09:08 AM
lou_harris
January 4th, 2007 02:42 PM
155thINF
September 20th, 2006 10:15 PM
Quick Reply: olds transmission
