Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Speedometer gear
Old July 1st, 2018, 06:33 PM
jwr7042's Avatar
Speedometer gear
I have a 70 442 455. 4 speed with 391 rear gears. The tires are 255x60x15 on 8 in rims. My speedometer seems to be about 10mph slow. What combination do I need?
jwr7042 is offline
Old July 1st, 2018, 07:32 PM
4speed455's Avatar
http://www.tciauto.com/tc/speedometer-gear-calculator/
Looks like a 15 drive gear and a 44 driven can you get you where you want to be.
4speed455 is online now
Old July 2nd, 2018, 06:50 PM
jwr7042's Avatar
Speedo gears
Where can I buy drive and driven gears
jwr7042 is offline
Old July 2nd, 2018, 08:02 PM
4speed455's Avatar
https://www.ebay.com/itm/GM-GMC-TH40...kAAOSwVK9bItNE
Here you go both gears in the same auction. Depending on what you currently have you may not need to change both. If you have to change the drive gear you need to drop the driveline and pull the tail shaft, which I did without even jacking the car up in like a half hour. Also you might have to change the driven gear housing. They are only good for certain gear ranges; 34-39 or 40-45.
Old July 3rd, 2018, 07:21 PM
jwr7042's Avatar
Speedo gears
I think you miss understand this is for a manual 4 speed transmission. With 391 rear end gears.
jwr7042 is offline
Old July 3rd, 2018, 07:29 PM
4speed455's Avatar
Yep, I breezed right past that important detail.
Old July 3rd, 2018, 07:48 PM
4speed455's Avatar
In that case you need 8 drive gear and 23 driven. Not sure if you have 27 spline or 32 for the drive gear.
https://www.ebay.com/itm/MUNCIE-4-SP...ss!95307!US!-1
https://www.ebay.com/itm/NEW-MUNCIE-...ss!95307!US!-1
https://www.ebay.com/itm/Speedo-Driv...IAAOSw6n5XtKuG
Docs72
October 8th, 2019 08:02 PM
4SPEED67
February 21st, 2018 05:41 PM
jpc647
29
September 8th, 2017 09:02 PM
delta254
Drivetrain/Differentials
October 18th, 2012 10:11 PM
74 Omega
May 26th, 2008 10:43 AM
Quick Reply: Speedometer gear
