Recharging A/ C 67 Cutlass
Rebuilt my original system and now looking to charge it. Have replaced all o rings, drier, and converted to R-134. Have pulled vacuum on the system and all seems fine. My question is which pag oil and how much do I add to the system? I removed as much original oil from the A6 compressor as I could. I will have to recharge it with cans as I don't have access to anything else. Do the cans of refrigerant already contain oil? Thanks.
You add the oil prior to pulling the vacuum. Usually, you remove the compressor, and drain the oil from the sump. The oil is running throughout the system, so you should flush as much out as possible.
