Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Tips for backing off drum brake
Old February 7th, 2016, 02:09 PM
70 Cutlass SX
pcard's Avatar
For 1970 Cutlass Rear Drum Brakes
As can be seen from the image I do not have a slot in my backing plate for backing off the brake adjuster. ( Reproduction kit from InLine Tube)
Aside from cutting a slot in the plate does anyone have any trick I can use to slack off the brake shoes?
pcard is offline
Old February 7th, 2016, 02:39 PM
There is not an area that needs to be punched out?
oldcutlass is online now
Old February 7th, 2016, 04:12 PM
70 Cutlass SX
pcard's Avatar
Hi Eric, I do not see one. Here is another angle:
pcard is offline
Old February 7th, 2016, 04:13 PM
70 Cutlass SX
pcard's Avatar
I do not have access to the car at the moment so have to rely on photos taken previously. There may be a notch but it is behind the centre line and I thought the slot was dead centre and just above the lower flange of the backing plate.
pcard is offline
Old February 7th, 2016, 04:20 PM
Octania's Avatar
Dremel cut a similar slot in the drum instead?
If you use a rubber plug to size the slot, you will have a ready solution for sealing it.
One of the problems with reproduction parts from ANY vendor is the lack of attention to detail... like, what if you need that access port someday?
Octania is offline
Old February 7th, 2016, 05:31 PM
mrolds69's Avatar
Take the wheels off, whack the drum up, down, pull off the drums. THEN mess with the slot. You have been in there before, right? No way you could have a ridge built that you couldn't get the drums off.
mrolds69 is offline
Old February 7th, 2016, 06:35 PM
Yellowstatue's Avatar
I have also seen drums with the knock-out on them.
Yellowstatue is offline
Old February 7th, 2016, 07:28 PM
It looks like there is a knockout on the bottom of the backing plate. Look at the pic in post #3.
Old February 7th, 2016, 07:42 PM
70 Cutlass SX
pcard's Avatar
Eric: here is an image from the Inline Catalogue. I am not sure that the indentation in the centre is a knock-out.
pcard is offline
Old February 7th, 2016, 07:47 PM
I'm just going by what I see in the picture in post #3. I may be wrong but it sure looks like a knockout there. You'll just have to wait and see.
70 Cutlass SX
pcard's Avatar
If there is no knock out then I will cut one out if I can't persuade the drum off gracefully. No big deal with an air tool.
pcard is offline
Old February 7th, 2016, 07:48 PM
70 Cutlass SX
pcard's Avatar
Thanks for working with me. I still want to make it out to Texas!
pcard is offline
Old February 7th, 2016, 07:50 PM
The drum should still slide off. Come on down...
Old February 7th, 2016, 07:57 PM
mrolds69's Avatar
X2.....the knockouts would be below the indentation to the LT or RT. Some drums also have knockouts, then you plug the hole. The knockouts are like on electrical outlet boxes.
File Type: pdf
mrolds69 is offline
Old February 8th, 2016, 11:44 AM
70 Cutlass SX
pcard's Avatar
Thanks for that - I was going to ask for a schematic showing exactly where to cut the slots, but the diagrammes in the article give me what I need if I have to make the cut.
pcard is offline
Old February 8th, 2016, 12:29 PM
mrolds69's Avatar
Sure...glad to help. Rememember that side to side is different, the slot has to be where the "star" wheel is. That's why they show 2 knockouts.
mrolds69 is offline
Old February 8th, 2016, 03:20 PM
therobski's Avatar
The 2016 Power Tour stops in I believe Grand Prarrie. I will be there, hoping to take the 64 F-85 Pro Touring car on its maiden voyage. Then up to OKC where the Tour ends. Sure be nice to get some of our Club locals out there to meet!!!
therobski is online now
Old February 8th, 2016, 03:23 PM
therobski's Avatar
MROLDS69 could be right Did you take the tire off yet? On my 67 the rear drums have the knockout not the backing plate.
Old February 8th, 2016, 06:20 PM
70 Cutlass SX
pcard's Avatar
Going from the CSM in 70 the B and C body had the slot in the drum. The A body has it in the backing plate.
pcard is offline
monzaz
January 4th, 2015 02:48 PM
501Paratrooper
Brakes/Hydraulic Systems
June 20th, 2012 11:35 AM
Flye
June 6th, 2012 10:52 AM
oldzy
October 8th, 2010 03:08 PM
one4theroad
October 27th, 2009 01:32 PM
Quick Reply: Tips for backing off drum brake
