Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Clutch fork felt?
Old November 3rd, 2018, 09:33 AM
Fpcopo's Avatar
Clutch fork felt?
i found a felt washer and a steel retaining ring under the clutch fork at the pivot ball in my 66 442. I’ve never seen one of these and can’t find a picture in the assembly manual. How does it go back in? Thanks much.
Fpcopo is offline
Old November 3rd, 2018, 11:36 AM
Phantom Phixer
Charlie Jones's Avatar
This may help ;
The complete catalog may be downloaded free here ;
https://classicoldsmobile.com/forums...n-catalog.html
Charlie Jones is offline
Old November 3rd, 2018, 12:52 PM
edzolz's Avatar
The felt washer would be number 14 in the picture.
edzolz is offline
Old November 3rd, 2018, 12:58 PM
66-3X2 442's Avatar
No,#14 is the rubber inner seal. The felt washer is #9.
66-3X2 442 is offline
Old November 3rd, 2018, 01:30 PM
Fpcopo's Avatar
Mike, 9 is the washer on the frame side of the cross shaft. This washer and retainer is under the clutch fork in the bell housing. It slides over the pivot ball but I’m not sure which way it goes in. Either the felt in contact with the clutch fork or the retainer next to the fork. You can’t see this particular felt and retainer in the pics.
Fpcopo is offline
Old November 3rd, 2018, 02:10 PM
66-3X2 442's Avatar
OK,I know which one you're talking about now.
Old November 3rd, 2018, 02:15 PM
My442's Avatar
The seal is the same , but he is talking about the seal on the bellhousing stud that the clutch fork pivots on inside the bellhousing.
My442 is offline
Old November 3rd, 2018, 02:18 PM
My442's Avatar
Pivot Ball Seal and retainer
My442 is offline
Old November 3rd, 2018, 02:21 PM
Fpcopo's Avatar
That’s it! Does the retainer go next to the pivot or the felt? Thanks guys, I couldn’t find anything on it any where.
Fpcopo is offline
Old November 3rd, 2018, 02:27 PM
66-3X2 442's Avatar
I think the retainer goes on first and then the washer. I think it's used to lubricate the stud over time. When I get time,I'll look in the service manual or parts book to see what the order and function is.
Old November 3rd, 2018, 02:28 PM
66-3X2 442's Avatar
The seal is the same as?
Old November 3rd, 2018, 02:35 PM
My442's Avatar
....the felt seal on the end of the Z bar.
My442 is offline
Old November 3rd, 2018, 02:37 PM
My442's Avatar
The retainer holds the felt seal, and retained by the spring fingers on the clutch fork.
Just put a small glob of grease on the end of pivot ball before assembling.
BTW, that metal retainer is super rare, as most of them were discarded at the first clutch job.
My442 is offline
Old November 3rd, 2018, 02:49 PM
Fpcopo's Avatar
Lots of knowledge on this forum. I couldn’t figure out how to get it back together because when I popped the clutch fork out the retainer and felt came flying out. Now I know it goes under the spring legs. Thanks again!
Fpcopo is offline
Old November 3rd, 2018, 07:17 PM
66-3X2 442's Avatar
Gotcha,thanks.
Old November 3rd, 2018, 07:18 PM
66-3X2 442's Avatar
That is a rare piece. I've never seen one in all of my years but then again,I haven't seen them all.
Old November 4th, 2018, 03:56 AM
rob1960's Avatar
Here's a pic from the '68 service manual showing the pieces. I had forgotten about them also when they fell out of my bellhousing!
rob1960 is offline
Old November 4th, 2018, 04:27 PM
Fpcopo's Avatar
Once I saw where it went, it popped right into place
Fpcopo is offline
4speed455
April 16th, 2020 07:48 AM
OldsAl
May 28th, 2018 08:04 AM
Globeguy
April 29th, 2017 10:25 AM
bummerino
October 25th, 2011 08:28 AM
bummerino
April 27th, 2010 08:55 PM
Quick Reply: Clutch fork felt?
