Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Anyone complete an alternator conversion on a 54 Rocket 88?
Old September 4th, 2018, 09:17 PM
Phelics32's Avatar
I am looking for help from anyone who has done a conversion to an alternator on a 54 Rocket 88 or similar. Specifically I am looking for help with the wiring. If anyone has a wiring diagram for this vehicle I would greatly appreciate it.
Phelics32 is offline
Old September 5th, 2018, 07:16 AM
Tedd Thompson's Avatar
Post this question in a different forum like the electrical or vintage forum and you will get better response. This is a common conversion and should not be hard to get a answer. Do you have a single wire alternator (internal regulated) or are you still going to use the external regulator? ... Tedd
Tedd Thompson is offline
Old September 5th, 2018, 08:43 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I have one on my 54. It is a single wire and the wiring is simple. You run a wire from the alternator around to the other side where you positive battery cable connects. I got the wire at Home Depot and I think I used 8 gauge wire. I did have to make a new mounting bracket to get the pulley to line up correctly.
redoldsman is offline
vigor47
November 30th, 2014 09:15 AM
boc23
August 22nd, 2014 08:13 PM
neller840
August 5th, 2011 06:15 AM
Autobahnzerreisser
July 26th, 2009 03:08 PM
Quick Reply: Anyone complete an alternator conversion on a 54 Rocket 88?
